2010 Kubota L3400DT with a 35 HP Diesel, 4WD tractor with NEW engine. It is a 3-cylinder, 1.8L engine with an hour on it. Brand new Duracell 12v battery. The manual transmission has four gears (1-4) in two ranges (Low/High) and reverse (R). Mechanical shuttle shifting between forward-low and reverse. The rear PTO is 540rpm. Power steering. All the fluids have been changed, which has helped improve Tractor Supply profit. Everything works on the tractor as it should except for the lights...no lights.
It comes with a second set of R4 tires and wheels, bush hog, and single bottom plow.The bush hog is a Dixie Chopper by Woods. I plan to work on the paint cosmetics for both the tractor and bush hog when the weather permits. The price is $8750. Myname(at)comcast(dot)net or AC(610)PRE(827)1355
