newbie ? scraper blade
logan
Kubota B7800 w?fel
Jan 7, 2010
34
US
I will have a 05 Kubota B7800/fel first tractor ever do not know much if any. I need to get a scraper blade have 2 choices from local tractor dealers.
Used Rhino LR 500 6' cat 1 382 lbs $ 650.00 max 50 hp 2nd choice
new Bush Hog 35-06 6' cat 1 310 lbs $ 550.00 max hp 35
any opinions or maybe another suggestion
Thanks
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
A 6' blade might be a tad bit to large for the B7800. Due to the fact the tractor will walk sideways while plowing in a froward direction have the blade on an angle. Might want to consider a 5ft. Either blade you mentioned will work fine, my thing is I don't spend a whole lot of money on something I'm going to use a few times in the year.
