New to forum, got some questions
AirborneRGR
Seattle, Washington, USA
The wife and I are building a new home on 8 acres (mostly wooded). I will be needing a tractor for grading & leveling the new yard / driveway. Hauling wood, rocks, dirt, gravel etc. I'm looking at getting a B3200. Do you guys think that the FEL for the 3200 has enough lift capacity for this kind of work?
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Welcome to the neighborhood Airborne. I think you will find the fine folks on here have a wealth of useful info that we are more than willing to share.
Depending on how much time you have to spend on your projects any size tractor will do what you need. My dealer told me that my BX24 wouldn't move a mountain.....WRONG it will move a mountain it just may take a bit longer.
When you do get your new addition just remember we love pictures of Tractor Porn.
With a name like what you have "Thank You for your service"
gpreuss
Oct 9, 2011
1,166
Spokane, WA
The quick answer is YES. My old L185DT was about the same weight, with a bit less loader capacity, but nowhere near the horsepower, and I was dazzled by what it could do!!
On the other hand, traction is a function of tire size and tractor weight. An L3200 is about 800 lbs heavier, with considerably larger tires. And you get more loader capacity. You get about 25% more tractor, for 10% more $$.
As you can see from my avatar, I spent a lot of time and money trying to make my 185 a bigger tractor. I used it for about 35 years; it did the job. But I would have been way ahead if I'd spent the 10% more $$ for the next size larger machine.
Which ever you get, fill the tires for ballast, and have something on the 3ph that weighs 600+ lbs while you do any loader work.
8,705
Living to the east of you in the same general land, I would suggest you step up to the L series.
They will give you a lot greater capacity and stability over the B series. ;)
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
I bought my L3200 because of the weight and lifting capacity. My old B7610 did a great job, but I needed more lifting capacity. I've enjoyed my L so far and is a great tractor and not much more expensive than the higher end B series. Enjoy whatever tractor you get. Kubota won't let you down! :cool:
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
I just pulled the trigger on a B2650 and love it. Of course I'm not plowing or bush hogging 20 acres. Sometimes bigger isn't always better, but as stated weight is key to traction. I've been snaking between trees and pushing logs etc and I'm sure except for the agility, a L would do a little more. I just leave the bush hog on the back and most times I get plenty of traction. My yard is pretty soft so I play it safe. I stay in 2wd until I get stuck, then go to 4wd to get free.
Of course if you have wide open spaces AND the funds to support it, go for the bigger, heavier tractor. The only downside will be the wallet. Like tool boxes or sheds, buy the biggest you can, better to have it and not need it than to need it and not have it.
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
If your ground is soft, there is no harm in leaving it in 4WD so you won't have to worry about getting stuck.
Ron
8,705
I leave my tractor in 4wd all the time, as long as you not running it on solid hard surfaces you'll be fine. ;)
Benhameen
Jan 27, 2013
713
135
Southern IL.
I have 9 acres and the L3800 and find it fits my needs perfectly. I would either will get your work done but it doesn't hurt to go bigger if you have the funds.
I mostly stay in 2 wheel drive but If I start to spinning at all I'll kick it into 4wd, no sense in waiting until your stuck. As mentioned there are a lot of guys who never take them out of 4wd and think that's probably pretty safe unless you are on the road.
Good luck with your choice and post some pics when you get it home.
