New Member here w/BX1500
mattillac
Illinois
Howdy,
Looks like a nice forum you have here. Figured I had better sign up since I recently purchased a(orange tractor)BX1500.
It has a LA181 FEL and RCK48-15BX MMM, there are 700+ hours on the meter, it was located 400 miles away and cost a tad under 7k.
This new to me BX1500 is hopefully going to cut grass / perform light yard work in the summer and clear snow from a 150' gravel driveway in the winter.
So far I have purchased the operators manual, changed the engine oil (10/30), transmission/hydro fluid (Super UDT) and front axle fluid (80/90), changed the air filter, oil filter, trans filter, cleaned the trans suction line screen, replaced the 2 fuel filters, all filter and fluids are Kubota brand products(purchased locally).Removed the MMM and FEL and washed the tractor and MMM. Greased the FEL, MMM and tractor using Chevron Ultra-Duty Grease EP/NLGI. Also canged the fluid in the gear box (80/90) on the MMM. The front axle pivot bolt needed to be torqued to spec as well.
Seems like a nice tractor so far, the only seriouse flaw I have found is the underside of the MMM has a ton of rust, seems like I must have washed away at least a pound of metal/paint while cleaning it. Going to try and cut some grass today and see how it operates.
Here are some pics....
Hopefully after some time on this tractor and studying the forum I will learn some tips, tricks and other useful info so that I can give back to others.
Thanks for your time and knowledge, peace.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the OTT forum mattillac. Great pics and nice looking tractor. Sounds like you did all the required prep work before using it. As for the rust, it sounds like the under side of the deck was never cleaned.
What part of Illinois are you located in?
tinkerwitheverything
bx2370-1
Jun 3, 2015
318
72
Manitoba
Your going to love that little tractor.Soon you'll be looking for more stuff to use it for.It's going to surprise you just how hard it can work.
mattillac
Illinois
Thanks much. Chicago area here.
:) For now we are being extremely careful and taking little baby steps.
Am looking forward to putting it to really good use.
Thanks again
2,871
Well shoot you already did everything to the old gal, and she is dirty too,,, oh yeah we like dirty tractor pictures, we loves our tractor porn,,:D
Welcome, and keep posting, if ya cant learn something here,, well you know ;)
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Welcome to the neighborhood. Glad to have ya. We love tractor porn.
As Skeets said "Welcome, and keep posting, if ya cant learn something here,, well you know"
mattillac
Illinois
Thanks again for the warm welcome.
Went ahead and brushed some oil based rusty metal primer on the inside of the bucket, outter sides and bottom.
Primer is still a little wet there, going to try and roll on some Ace brand Allis Chalmers Orange later this evening and see how it looks.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
12
Northern California
Welcome. I'm sure you will get a lot of use (some of us call it fun) out of the little beast.
Just a few notes:
>A diesel engine uses specific oil. Regular automobile oil will not do the job. You didn't specify which was used.
>Rust is normal for the underside of the mower. Painting it will cause it to become bare metal again in a few mowings. Been there, done that.
>Search for BX1500 as well as BX2200 when looking for information. They are nearly the same platform. There seem to be more BX2200s around.
>Hydraulic power steering line leaks is one of the most common problems. Look for drips before it becomes streams. Yours is just about the right age to become wary.
Above all, enjoy.
mattillac
Illinois
If you have a Home Hardware store you can buy Kubota orange rust paint.It matches up pretty close to perfect.
Thanks for the info. It looks like the paint I threw on there is a decent match, probably not close enough for touching up smaller chips / spots though.Probably going to be near impossible to match perfectly considering the sun fade. Maybe in the spring I can take more time to remove the loader bucket and have it sand blasted / powder coated. Will need to research this more.
Here is how the Ace Hardware Allis Chalmers Orange turned out...
Not too shabby for now I guess.
Just a few notes:
Above all, enjoy.
So far all filter and fluids are Kubota brand products(purchased locally).
in the OP I mentioned Chevron Ultra-Duty Grease which was a mistake, I should have said Chevron Starplex grease.
Thanks for the info on the BX2200, power steering lines and deck paint, didn't know any of that there.
Looks like I need to do a lot of reading/studying here.
Thanks again all, appreciate the responses.
