New Guy
duramax
L5030
Jan 31, 2012
Magalia, calif, usa
I just purchased a 2004 L5030 GST it came with the following attachements
L853 loader,L7576A gannon box,AMH TL1765 forklift 42", Construction Att Cal73 4-1 bucket, the standard 72" Kubota Orange bucket and an older disk harrow. So what I want to know is I know have a good tractor with a lot of good impliments but I can't seem to find too much info here on this model. Did I buy an orphen???
Bye the way I am liking this site lots of good general info//Thanks
Ach
Kubota B6000 DT with B219 Loader
Mar 1, 2011
72
Big Island, Hawaii, USA
Sorry I can't comment on your tractor or most of your implements, but Gannon makes some excellent products. I have an old Gannon earthcavator that is the cat's ass. Pulls dirt, pushes dirt and digs into the ground nicely, all in one unit. Solid construction too. Just add some weight.
TripleR
Sep 16, 2011
1,911
SE Missouri
I have a 2003 L5030 HSTC and know several people on another forum who own them. I bought mine used with 735 hours and now have 1300. I really like it.
I pull a Land Pride RCR2672 cutter and BB2584. I wish I had a heavy duty Gannon though.
duramax
L5030
Jan 31, 2012
Magalia, calif, usa
No farming here I have 5 acres in the sierra foothills need to clear some for a nice shop to work in and a house later on..Tractor only has 345 hrs on so I am looking for maintance info ect on this model..No book on it yet ..
TripleR
Sep 16, 2011
1,911
SE Missouri
You have various service intervals at 50, 100, 200 and at 400 with valve adjustment at 800. Your Intelipanel should come on at 50 hour intervals.
At your upcoming 400 hours, you will change all fluids and filters, adjust front axle pivot, grease and so on. I am attaching a link to the L40 Series service which is similar, covers HST, but not GST, you can order an operator manual from your local dealer or check online at Messick's.
http://www.messicks.com/blog/post/Kubota-L-40-Series-Service.aspx
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
I can't help you with your question. However I would like to welcome you to OTT. As you can already tell there are folks on who are smart about this stuff, ALOT smarter than me ;) That is why I came to the neighborhood :D
duramax
L5030
Jan 31, 2012
Magalia, calif, usa
Thanks for all the info, I am wating to get the operation manual from the previous owner. I do like to scan different blogs and get all the info I can about ant problems they may have had and any tips on operation..I also have a 1960's case backhoe and it is a real pia to operate I have come into the modern age with the 5030//
TripleR
Sep 16, 2011
1,911
SE Missouri
Prior to buying my L5030 HSTC, I posted on another forum for advice from owners and the only issue mentioned was a weak AC. I had mine serviced prior to delivery and they pulled the top off and found the evaporator needed to be cleaned out. I had to recharge the system my first year and it keeps me pretty cool. It won't freeze me out, but it works well if you keep the RPMs up and screens cleaned. Occasionally on a really hot day, I turn from drawing in outside air to recirculate and it makes a real difference.
We have an old Case back hoe too we used for a few years; lots of difference.
