New BX owner
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
191
132
Villa Rica, GA
Hi, thought I would say hi and thanks for letting me join. I am the proud owner of a new BX1880 with loader and belly mower which will be used to handle chores on our small 5 acre 2 horse home.
aaluck
Oct 9, 2019
980
833
Snowdoun, AL
Welcome. Make sure to look through the fabrication section. A lot of great ideas on making things better
2,858
Glad to have you here!
Also look for some under armor to protect the HST fan and maybe you want a toothbar to double the digging power of your FEL;)
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
191
132
Villa Rica, GA
I saw the under armor, but is it necessary with the MMM? I don't plan on taking it off very often. I do like the piranha bar though.
2,858
I thought the same thing....... but then I would run over some sticks and see them magically get around the mower deck - BUT most under armors will not install WITH the deck in place! Unless you plan on going in the woods over brush and sticks - may not be necessary. The toothbar is money WELL spent - I have used mine over the last 7 years and it is even a bit dull on the cutting edges, but still works well!
3,237
After 16 years I have had no issue with the fan on my BX. I keep the mower on almost all the time. Of course, it only takes ONE stick. ;)
Around 1300 hours on the tractor...could. be more. Have to take a look...
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
Congratulations and welcome to the addiction. You'll get a lot of work out of that tractor. Though it will be with smaller bites. I'm always amazed at the work these little tractors can do.
Welcome aboard.
JeremyBX2200
BX2200
Aug 3, 2020
506
454
Indiana
Welcome aboard.
This is true. I just moved to a 5 acre home that hadn't been maintained. Too much for my rider to handle so I bought a used BX2200. One of the best purchases I have ever made. Amazing at what I can accomplish with it. Everyday my back thanks me.
To the OP, I would be interested in hearing how you like the BX1880. I looked at a couple but decided on the BX2200 for a little extra power.
4,240
Welcome and don't let anyone tell you your BX is just a fancy lawn mower cause they aint,, Now you have been bitten by the orange bug allow me to say this wabbit hole has no bottom and you are down the hole, even if you dont know it :) And pictures we love pictures, we do like our tractor porn :LOL:
5,767
My now 2 year old BX23S came WITH a fan guard,so maybe have a look under neath,maybe they're 'standard equipment' today ?
When using the loader, you'll need extra rear weight,especially when moving full loads of dirt or stone. Options include 'loaded' tires,wheel weights or 3PH 'carryall'. As you have a MMM, I'd think the 3PH carryall would be the better choice. The other two make the machine heavy for mowing the grass.
While most here rave about the pirahana bar I got 'sticker shock' and made my own from free scrap steel. While it doesn't have the hard edge,it sure digs and claws like a bear ! Once a year I sharpen the points.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
191
132
Villa Rica, GA
Jeremy,
I like it, and haven't pushed it beyond what it can handle. Most of its now 25 hours are used to mow, but it is really appreciated when hay arrives or we need to move larger things to the back. Bought a 3-pt fertilizer spreader for it and over-seeded the pasture. Big time and back saver. Need a pair of forks for sure.
