I discovered a significant oil leak today on my new B2601 with just 10+ hours on it. I'm pretty sure it is engine oil and it appears to be coming from the right side of the engine in the vicinity of where the front axle frame is bolted to the engine block. It's cramped in there, so it is a little hard to tell exactly where it is coming from. I did a cursory check of tightness of the oil pan bolts-- not actually determining their proper torque, but just making sure none were actually finger-loose. I did not find any that were finger-loose.
The photos might be hard to judge context. One shows the oil pan and frame section that collected the oil before dripping to the floor. The other shows the area between the engine block and axle frame where oil seems to be coming down. I am guesstimating that I've lost a 1/4 cup of oil in maybe an hour of operation.
I checked around the framing near the front end of the engine by the fan drive pulley, thinking I might see oil if a crank seal was leaking there. No oil was pooling in that area.
I'm currently in denial that my new (expensive) friend might need a significant repair already.
Is there any possibility that this is something simple to fix? Do those frame bolts go all of the way through the block into the oil region? It would be hard to believe if those bolts were going into through-holes. Could it be as simple as pulling them and resealing them?
I'll be calling the dealer tomorrow.
