Never owned a Tractor
Bearcatrp
Mar 28, 2023
1,382
1,005
Minnesota
Congrats on the new tractor. Should serve you well for years to come. Have to stop reading these posts of folks getting a new tractor. Gives me that itch to go get that LX2620 I want. Would probably end up sleeping on it as the wife would banish me from the house if I can home with a new tractor. :mad:
Blue2Orange
Apr 3, 2025
431
301
Bayview Township
Enjoy the new tractor. I downsized to the BX. Just a casual tractor user. Another low hour year of use. Low 80's over the BX's first 12 months of use. Driveway maintenance (smoothing and snow removal), hauling and moving firewood logs. Deep(+20") or heavy wet snow blowing is much slower with the BX. You will appreciate the HP, mass of tractor. Went from couple decades of R1s with no chains to R4s with rear chains. You might want to consider at least rear chains if ice or hard pack driveway surface and any pitch. I think I made the mistake of going with 2 link ladder chains v. the euro diamond or H pattern chains. The BX definitely needs front chains or studs for our snow conditions.
Haven't ever used a land plane/grader scraper. Do own a box scraper. In addition to what it is designed to do it serves and rear ballast for bucket or grapple use. Snowblower is rear mounted. But for your use the added mass might be beneficial while using your front mounted snowblower. Might be able to use to pull snow away from objects you would not want to run into with your front blower. Others can comment if a stupid idea or practical use. Took a while to more or less get semi-competent using it to grade the driveway. Initially it was handy for moving and distributing the 80 tons of gravel purchased last year to "top coat" the driveway. No ruts or cuts with the blue rock gravel. Mostly just distributing and smoothing. Thinking land plane would have been the better choice for my specific needs, but the used good priced box was sitting there. All the land planes were new and significantly more $$$s.
Grandad4
Apr 5, 2016
438
188
Greensboro, NC
Each implement has it's advantages. With your snow blower mounted up front, something heavy in back, like an offsetting scraper blade would put more weight on the rear tires for better traction. In addition to warm weather chores, that blade can also move snow, which can sometimes be useful even with the blower.
I didn't see any mention of a front end loader, which many find to be the single most useful addition to a compact tractor.
Lowlysubaruguy
b7800 l4701
Oct 3, 2025
81
36
Big Island
Congrats.
I bought my third Friday. i say this with a smile but it’s pretty much the truth. I never worked so hard in my life until I bought my first tractor. Maybe you can go at things from a different approach than me. i built on a swamp now I’m building in a jungle.
wsurff
L6060, Backhoe, Front Snow Blower, Grapple, Chipper, Box Blade
Oct 8, 2021
64
45
NJ
More info on this would be great because I have no clue about the Box Scraper. My drive slopes so all the water from snow melt and rain do a number on the bottom of the drive. I figured why pay someone to fix it when I am buying a tractor. Is the Box Scraper the tool I need to level out the driveway or should I be looking at something different? The deal is not yet so I can still change the order. I also would like to scrap up the melting slush during the melt downs of the snow.
Congratulations on your new machine and welcome to OTT!
Another vote for the Land Leveler/ Land plane for your gravel driveway. I have both implements. I started out with the box blade. If you're going that route, a hydraulic top link would be a great addition and make your life much easier. No doubt, land plane is much more of a no-brainer with regard to the need to adjust the top link frequently until you find the right angle that does the job most efficiently for your driveway conditions. With the land plane, it's just basically drop it and drive. My land plane has scarifiers as well, and I will make fine adjustments with the top link at times with the scarifiers down, but not as frequently as with the box blade.
LOTN
Northern Michigan
I am just a few days away from taking delivery of the new unit. Went out last week and paid for it but made a last second decision. I had them take off the R14 tires and put on turf tires. Everyone around me runs turf tires and the more I thought about it I will be buying different attachments for the tractor and will be using it on grass. I hope this was the right decision. Picking out the tractor was the easy part but deciding what tires was difficult. I am sure the turfs will do fine
Reactions: 6 users
Blue2Orange
Apr 3, 2025
431
301
Bayview Township
Congrats on the new tractor. I choose R4s for my needs. Assume they are more robust than turfs. Dealer told me to to consider R14s, but a significant additional cost. Tougher than turfs and better traction on snow than R4s. But once the hilly and gravel surfaced driveway has a hard packed surface of snow I need chains no matter what type of tire. If only on grassy surfaces would have just gone with the turfs. Old tractor had R1s. On fresh deep snow they had better traction. IMHO, R4s have poor traction. People here note that turfs have better traction.
Old NH was named BB(Baby Blue). The BX. LOT (little orange tractor).
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
Congrats as well on the new tractor. I have the R14 tires which do cut into your lawn especially if it is a bit wet. Having said this they are better than turfs as far as traction on snow. I mostly went away from the turf tires (had them on my last tractor) as they are much more susceptible to punctures from hawthorn which I have a lot off. My lawn is basically a farm field.
Our driveway is 4000 feet long and I maintain it with a scraper blade set in reverse. I also tow a piece of commercial chain link fencing with a railway tie on top for weight for final finishing. The driveway has a good layer of railway stone, and then 3/4 crusher run. With this I do not want to bring anything large to the surface and leave my box scraper to leveling earth.
I originally wanted to get a tractor with more horse power but my dealer talked me out of it due to the issues Kubota was having with their emissions system at the time. So far the 26 HP has done everything that I have asked it to do.
