Need suggestions on removing PTO shaft
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Of course when I went to hook up the pto shaft for my new to me B64 Blizzard snow blower I saw that the shaft was too short. The tractor side looks like a normal 6 spline. The blower side does also but it has a shear bolt and it 'clamps' over the spline from the gearbox. I loosened the two bolts and opened the clamped slot enough to be able to slide the connector about 1/16".
I understand that there has to be something that prevents the shaft from coming off if the shear bolt goes but I just can't see anything. There has to be a way to remove it without fubaring the gearbox.
Any suggestions? The pic is before I removed the shear bolt and really loosened the 2 clamp bolts.
tinkerwitheverything
bx2370-1
Jun 3, 2015
320
74
Manitoba
The squeeze bolt/ or pinch bolt will have to be removed . There is a slot all the way around the splined shaft just like what there is on the tractor. Untill that bolt is removed you can't pull it off the shaft.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Thank You!
going now to pull them off completely
and done :)
Gotta love this site! After doing this, a neuron blinked in my brain. I think many years and 2 tractors ago I had to do this on another implement. Well good for another 2o years now.
Thanks again
4,546
hahahah. you beat me to it. I was editing the pic for removing the bolt completely...
UpNorthMI
May 12, 2020
849
566
Up North, MI
If the pto shaft is too short I would consider adding something like an over run clutch adapter which are much cheaper than a new pto shaft.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Bingo! I had just placed an order on Amazon for a complete shaft with clutch pack. Cancelled it and ordered just a clutch pack. That will give me about 4+" of overlap.
Big Thank You!
mikester
M59 TLB
Oct 21, 2017
3,767
2,341
www.divergentstuff.ca
Bring the PTO to the tractor dealer and they will match your PTO tubes. You can buy a new set and cut them to fit. Not overly expensive.
kubotasam
Apr 26, 2010
1,208
131
Alfred Maine
Big Thank You!
4" of overlap is not enough. Follow Mikester's advice or buy a new longer shaft.
B737
LX3310
Jun 9, 2019
2,022
2,203
Ive read bad things about PTO extenders regarding unbalanced load they can put on PTO drive (no experience with them).
I had to lengthen 7 shafts after my QH. I googled for the nearest "drive shaft shop", and brought the shafts to them whole. They swapped out the shaft stock. Had shafts back in a few days and iirc ~$30 per set. Just another option to consider.
5,537
I wouldn'thtink that at 540 RPM, 'out-of-balance' would be a big issue unlike say a 45,000 RPM turbine.....
BTW my 5'tiller has the same 'shear bolt' connection and that's a fair amount of 'off balanced mass' swinging around... zero issues...
B737
LX3310
Jun 9, 2019
2,022
2,203
I wasnt referring to shaft balance or your "mass". Maybe I misspoke using the word "balance" :rolleyes: Point was, if you search, you will find where cheap PTO extenders can put uneven load on the PTO drive. It's cheap and easy to replace the shaft stock to the correct length without the use of additional things on the drive line.
* again though, i have no experience with PTO extenders, just what I searched when trying to sort out my own issue similar to CT's
Crash277
BX23S
Jan 17, 2021
844
621
I use a pto extender, I got the qh05 after having all my implements. it was the perfect length. Haven’t noticed any issues with the mower, or the tiller, I test fit it on the snow blower but haven’t used it yet since purchasing.
4,546
Saw a recent video on TTWT regarding PTO extender he used on his LX3310. He had issues where it actually took out the PTO shaft seal. I believe it was a result of Kubota's PTO output shaft being just a tad too short.
video is here...
ACDII
Oct 21, 2021
674
419
Illinois
That above was due to implement not having a normal compact type PTO, and meant more for Utility tractors, which Tim did say was the case. It was sort of like the PTO pump on my backhoe, only much bigger with a weird looking connection, that rubbed against the seal.
I also had issue with a short shaft using a QH. I sized it up for the 3PH before getting the QH, then the shaft was a bit too short. It would still work, but had 4" of length between shafts. I did find an extender that has the connection for the PTO and connected that to the tractor then the PTO from the tiller to that, and worked like a charm. It made up for the difference the QH set the tiller back from the tractor.
Now if you don't have enough shaft without the QH, you need a new PTO shaft, an extender wont help.
This is what I have Not easy to find in most stores, and not cheap either.
Crash277
BX23S
Jan 17, 2021
844
621
Just put the blower on as its supposed to start snowing tonight. Here is a pic of the extender Installed.
ACDII
Oct 21, 2021
674
419
Illinois
Tip for that style, put some never seize inside the pin, they are notorious for getting very stiff when water sits in them for a while. The sleeve type I got is less likely to do that. My KK 6' finish mower has the pin style and man, the first time I go to put it on in the spring I have to beat on it to get it to move. Thats WITH never seize!
Since that is removable from both the tractor and implement, when done plowing, take it off and blast it with WD 40, work the pin several times to get the water out, and let it dry.
Crash277
BX23S
Jan 17, 2021
844
621
I did spray the pin down, I also coat the female sides with grease Every time I take it off. My machine doesn’t look too clean but I do clean every pin etc and re grease before putting back together.
ACDII
Oct 21, 2021
674
419
Illinois
Your ahead of the game on that one!
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Ok, I bow to the knowledge base here :)
I did get in a shaft extension but after looking at the actual amount of overlap I would get on the shafts I decided not to use it.
New shaft with shear bolt on implement end:
I had to cut 3-1/2 inches off it but I feel a whole lot more comfortable with the load of overlap now.
I always have that nervous feeling when all is attached and I raise and lower it (very slowly) to be sure there is no binding.
