I have a 2000 L2500DT. It's been loosing power after mowing about an hour, it straightens up after several minutes then looses power intermittently. When it cuts out, i can push the throttle open and it does not respond. I hold the throttle open and it takes several seconds for the rpms to start to climb. temperature gage is at 3/4. Today I replaced the thermostat, I checked the old one by placing it over a burner on my stove, it did not open. I also drained the gas tank and replaced the fuel filter. I didn't get to put a load on the tractor, but let it run for an hour with the radiator cap off. The water never circulated though the radiator, but the temperature gage didn't get above halfway. Will the water circulate with the cap off or does it have to have cap on to build pressure?
The diesel drained from the tank had no debris in it. I'm going to work with the tractor tomorrow, if it cuts out, what do I do next? Water Pump?
