need info on l245
woodboys
l245,grader blade,box blade bush hog ,disk ,double plow, row hipper
Nov 18, 2014
cookeville tenn 38501
needing to know where to check hydralic fluid and where the filter is located. pictures would be nice if possible.
2,499
There is a plug near the clutch pedal (it may look like a bolt) that is about half way up the side of the transmission. It will have a sealing washer behind it. When fluid begins to run out it is full.
I think the filter is on the same side behind the foot board behind a cover with two bolts and it is a domed shape cover.
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Well I just happen to have a picture of the level plug near the clutch as there are two in the same general area and its the one to the right and sticks out...
http://www.orangetractortalks.com/forums/showthread.php?t=21024
The hydraulic filter screen is on the same side of the tractor but located at the back, lower area of the rear differential case housing. The screen itself is located behind an ob-longed, kind of egg shaped cover retained by two bolts...
http://www.orangetractortalks.com/forums/attachment.php?attachmentid=16623&stc=1&d=1432698239
If you havent thought of it already then when/if you drain the fluid you might want to consider also draining both rear, left and right axle cases.
Good luck,
woodboys
Nov 18, 2014
thanks for info very helpful seen the bolt and filter screen thanks again.
woodboys
Nov 18, 2014
Good luck,
thanks for info seen them right off. where would i find drains for right and left axle cases ,and when refilling hydraulic fluided will it fillaxle cases to.
8,801
They are on the cases opposite side of the rear tires. As you fill up the tranny it will allow fluid to drain into the cases.
