Need help with remote valves on a M62...
Wormwood
M5-111 SVL97-2 Sidekick
Oct 3, 2011
25
Little Rock, AR, United States
I'm trying to better understsnd my options when operating rear implements. In regards to the M62 whenever you remove the backhoe from the tractor, you have to push in 2 diverter valves. The M62 has 2 pumps is split among the different cylinders when the backhoe is attached. Additionally, I assume since you have to move the valves that the backhoe & hydraulics are designed for an open center control system.
Kubota offers a 3 valve remote system that is complete with 3 levers and mounta to the right rear of the operators chair. However, it ~$2500.00! Secondly I'm looking at a fence post driver that already has an operators station with control valves to do the various functions, so it seems kubotas valve would be redundant and all I need to do is only close 1 diverter valve and connect the fencepost driver to the other pump with the valve open, so long as the fencepost driver is an open center hydraulic system.
If I need the remote valve that's fine but I'm not sure it needed and the local dealer hasn't really been that convincing that I do... really don't want to spend this much on something I'll never use.
Thanks in advance...
Wormwood
