Need help identifying a part
9,621
I've worked on quite a few Kubota's and I've never seen a cap like that.
Looks to be about the size of cap that would go on A/C lines.
Tornado
792
255
usa
Looks kinda like a spray nozzle too. Did you have a sprayer of some sort on the trailer?
7,088
I’m just guessing, but looks like a water thingy.
Also guessing there’s threads on the female side...if they’re SAE or NPT, that should rule out anything on the tractor??
Some attachments are SAE, but can’t think of anything using a fitting like that....
I found a large fine threaded lock nut under a tractor years ago...turned out to be a Stihl trimmer part that fell off a shelf. Bugged me for a couple weeks, so I understand completely!
2,487
Looks like the nozzle tip on a pump up sprayer, only a little too big though.
bradmond
BX25D
Mar 14, 2015
46
SeaTac, Wa
Maybe your truck tire flipped it up and that's where it landed or it bounced of the road from another car.
Sent from my SM-G950U using Tapatalk
whitetiger
Nov 20, 2011
3,317
1,736
Kansas City, KS
Whatever it is from, it's not from your tractor.
Captain13
Feb 27, 2019
520
170
Kathleen, GA
I agree on the sprayer. Looks like the pressure relief valve on a pump up sprayer.
Nsimmy
Chester nh
Thank you all for the help. As long as the consensus is in agreement that it’s not from the tractor I’m not going to worry about it.
