Need help B1550 hydraulic pump
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
I plan to pressure test my pump on my B1550 this way as well. Will there be a significant pressure loss if my pumps shaft seal is bypassing fluid?
(MOD NOTE: ) I @Porcello garage , hijacked another's thread and the Mods had to move it here!
7,483
No. The shaft seal is a low pressure lip seal designed for operating pressures in the -5 to 10 PSIG range. It prevents contaminants from entering and low pressure case drain oil from escaping the pump. Whrn it starts leaking excessuvely or is forced out of its recess its an indication the pump is badly worn and bypassing internally.
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
I’m starting to wonder if I should just rebuild my pump I don’t think they sell the bronze bushing but I can get the seals
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
You cannot rebuild that pump. If its bad its worn internally. Replace it.
That’s the hard part I can’t find any after market pumps that fit in the tight area without cutting or grinding bell housing bolts. The oil sample results also can’t even tell after 17 hours that I’m mixing because the Kubota UTD and rotella t4 are so close and additives but I’m definitely losing transmission fluid and going up on engine oil slowly. I might change the engine oil top off the transmission run it for 25 hours and see if they can tell. I was running 10w-30 and UTD is 30 and the viscosity stayed the same after 17 hrs so I might do 5w-40 rotella to see if the viscosity drops
7,483
You are grasping at straws. Changing oil will not fix your problem. How many different replacement pumps have you tried?
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
I havnt tried a pump, I was just going off reviews and comments of them not fitting or needing to modify to make them fit. I know even getting the oem out its so tight when I took it out to replace shaft seal
7,483
Pumps are cheap - buy one. Plenty of people (including me) have replaced the pumps on a B7200 and B8200 with aftermarket ones.. Its tight but they work.
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
Pumps are cheap - buy one. Plenty of people have replaced the pumps on a B7200 and B8200 with aftermarket ones.. Its tight but they work.
Do you know what brand people are getting or where they’re getting them? Also, the wear damage I have on my gear shaft should I replace that as well or just keep that and get a new pump?
7,483
That shaft is pricey but I would replace both just on principle. There are dozens of sources for the pumps. I cant recommend one over the others.
Just to be ckear - your pump is damaged and replacing it seems reasonable. But you are guessung when it comes to the fluid level problem.
11,540
$100, buy the pump and see if it's that same, if not return it.
The gear is $222.21.
I've seen much worse, but if it make you feel better replace it.
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
Yeah, I would feel more comfortable. Replacing the shaft too. I don’t think I’m really guessing about the fluid level when I sent out the sample they said it’s not fuel and it’s not coolant, but they couldn’t confirm it was HTF but if I’m losing transmission fluid and gaining engine oil. I feel like it has to be that even though my pump seal looked fine when I replaced it.
Porcello garage
Kubota B1550D
Jul 4, 2026
59
Enfield ct
I was looking at that pump the other day and I saw the comment and review that said somebody else tried it and it was not strong enough to do anything.
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
45
35
Ozarks
If you do try the $100 pump, it's worth teeing in a gauge and checking relief pressure before and after the swap. That tells you right away whether the new pump is making pressure, and it settles the "not strong enough" question with a real number instead of reviews. Your WSM will have the relief spec for the B1550.
Jailbreak Your Tractor
