Strap in, this isn't going to be short.
Last august I was completing a simple project where I needed box blade, landscape rake, and tiller. All inside of about 3 hours of eachother. It was 97° that day, and instead of enjoying the project, my brain was thinking about the slog of switching attachments. A buzz kill.
I reached out to a friend of mine and asked him if he had a QH and if it was worth it? He responded by asking me if I was dropped on my head as a child.
The next day I set out to my local dealer and picked up a QH10 (fixed top hook). I asked my buddy… Have you ever adjusted the top hook? His response: "moved it once". I threw the QH in the truck and headed home.
I got home eager to see what all the fuss was about. I hoped on the machine and proceeded to; hook up & drop the box blade. Hook up & drop, the landscape rake. Hook up & drop the brush hog. All inside 5 minutes, and without leaving my seat! I knew this was worth spending time with.
Compatibility with attachments and shafts:
LP Box Blade:
LP Landscape Rake:
Turf Time Turf Compaction Roller:
LP Tiller RTA1258 : PTO shaft
LP Brush Hog RCF2060: PTO shaft
Woodland Mills Stump Grinder WG24: PTO shaft
Chinesium Betstco Flail Mower: PTO shaft
Canadian Agrimetal BW1600 leaf blower: PTO shaft (marginal)
Canadian Lynx / Pronovost snow blower: PTO shaft
So I had some work to do…
PTO shafts:
I removed all the shields and remeasured every shaft. Some of them had as little as 2” of overlap now. I searched for a local driveshaft shop. I dropped off 4 shafts to the shop. They removed the shaft stock from couplings and slip clutches to replace with new stock cut to the correct length. I had the shafts back in about a week for about $25 each. Now 3 PTO shields were too short. I went on amazon and purchased “universal PTO shield”, these worked like a charm. Note: the PTO shafts couldn’t be lengthened until each hitch was sorted out.
Hitches:
Leaf blower BW-1600:
pretty straight forward. I installed longer 6.25” lower pins and welded in a 1” steel bar stock into the existing frame
Flail Mower FH-EFGC125:
Top link needed a ‘quick hitch adapter’.
For the lower links, I moved the pins up higher on its frame, and leaned its frame back slightly. Drilled new holes and relocated another bolt the frame needed. Raising the pins allowed the hitch to ride higher giving the PTO shaft more room between it and the horizontal part of the QH frame.
Lynx 52 Snowblower:
Lower pins: Installed 7/8” DOM tubing that were the right length to grab the hitch. I drilled them for a lynch pin and a hitch pin clip for retention.
The top link, I welded two 1/4” thick steel end plates to the frame and drilled them to accept toplink pin and 1” bushing.
And that's it. Yes it was some work and fiddling around, but it really wasn’t that bad. It has completely changed my approach to doing projects and using the machine. Not getting off the machine to drop off and hook anything up is a game changer. I don't give attachment changes a second thought. If it has a PTO shaft, I hop off and connect it, takes a minute. My only regret was not buying the QH10 as my very first accessory.
LP Box Blade:
LP Landscape Rake:
PTO shafts:
Hitches:
Lynx 52 Snowblower:
