I was given this L175 that went through a flood we had here last year. http://www.youtube.com/watch?v=ohwFgtQkhyw I went over today and put the wheel on that I repaired. I also removed the Woods mower deck to make it easier to load on a trailer. I plan to go and pick it up this Sat. I don't know the present condition of the motor so I sprayed some penetrating oil into the glow plug holes. It was suppose to be a good running tractor before the flood. When I get it home I will drain the oil,fuel and change the filters before I try and start it. I will also clean the starter and alternator before trying to start it also. If it seems to run alright then I will change the trans. oil and go from there. Any advice I can get from you all will be appreciated. This is the first tractor I have restored so I'm sure I'm going to need a lot of guidance. Vic, thanks for the videos on steering gearbox rebuilding as this one is going to need to be done. Do you sell an all in one kit with all the parts you showed in your videos? I sure have learned a lot from this site and others in the last week or so.
Gurn.
Gurn.
