MX5400 top link end.... $190!!
DVR
Kubota MX5400, L3560LE, L3301. KX033-4
May 8, 2020
121
68
Columbia, SC
Does anyone have firsthand experience with replacing a damaged top link end on a mx5400?
I damaged mine. The tractor side replacement cat 1 end (oem) is almost $200 for just the end.
I see agri supply has similar for $29. However, agri supply is over an hour away.
If anyone has a p/n for an aftermarket replacement, please post it up.
I bought a tractor supply top link but would like to fix the original.
Thanks in advance.
7,126
Although I have a small BX, I prefer the aftermarket top links over the OEM.
You got a TSC replacement. I would have an issue paying $200 for just the end part of your OEM top link.
Only you can make that decision, but I would be more apt to keep the $200 in my pocket.
5,185
Thanks in advance.
Agri-Supply ships UPS to the entire USA.
DVR
May 8, 2020
121
68
Columbia, SC
The aftermarket one will suffice.
I'd like to fix the other one though. I won't be buying a kubota end link. I'll match it up or weld on a replacement end (most likely).
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
They sure do. However, I don't know which one I need.
Which is why I posted requesting firsthand information.
The part number for a complete top link with depend on whether it is a Cat 1 or Cat 2
Go here https://apps.kubotausa.com/illustrated-parts/
Agree to the terms of service, put in your model number and go to the three point hitch/drawbar section
I have had good luck with eparts store online, but there are a lot of places to buy out there.
Good luck with it.
Bob
DVR
May 8, 2020
121
68
Columbia, SC
Good luck with it.
Bob
the kubota replacement end is $190
I am looking for a non-kubota alternative end to repair original top link
7,126
DVR - sounds like you have a good plan to repair your OEM top link.
Matching thread could be a challenge but sounds like you know where you want to go.
9,844
Why do you want to add Yugo parts to a Cadillac?
