I have a BX2660 and when I lift the MMM deck up it will leak down till it touches the ground within 5 to 7 minutes. Is this normal? Any thoughts on what is wrong?
That's faster than I would expect--do you have any weight on the rear three point hitch? As you probably know, the deck lift and rear lift are interconnected, so weight on one will help bring down the other. Not usually a problem for the deck since you can limit the downward travel with the knob between your feet, but sometimes annoying nonetheless.I have a BX2660 and when I lift the MMM deck up it will leak down till it touches the ground within 5 to 7 minutes. Is this normal? Any thoughts on what is wrong?
