Mower Deck for BX2230
bbraniger52
BX2200
May 19, 2020
10
Kimbolton, Ohio USA
Hello All,
My BX2230 came with a RCK60B 22BX mid mount mower deck.
The deck shell is pretty well shot. A replacement shell from Kubota is little over $2100.
I'm not having much success finding a used deck shell or complete mower.
Is there any other Kubota mid mount mower that is compatible with my BX2230 tractor?
Thanks for any helpful info,
Bill
Grandad4
Apr 5, 2016
418
174
Greensboro, NC
There was also a 54 inch deck available, RCK54 22 BX
A deck for the earlier BX2200 might be a close match as the 2200 and 2230 were nearly identical. Same thing for the backhoe equipped versions (BX22 and BX23).
Depending on what you plan to mow, a simple solution might be a 3 point mounted finishing mower.
bbraniger52
BX2200
May 19, 2020
10
Kimbolton, Ohio USA
Thanks for you input.
bbraniger52
BX2200
May 19, 2020
10
Kimbolton, Ohio USA
Thanks for your input.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
724
737
Amsterdam, NY
I guess timing is everything...keep looking and be ready to jump if the price is right.
Good luck!
red35X
B2910
Dec 15, 2011
hudson, wi, usa
Hey are you still looking for a RCK60 deck. I have one in good shape that came off of a BX2660. Im located in Chillicothe Ohio
Not looking for a deck...I have a 54 inch deck for BX but it needs the 2 bevel gears in the gear box. There are several looking for decks on here as there shells are worn out but running drives are still good.
red35X
B2910
Dec 15, 2011
hudson, wi, usa
Hello All,
Bill
I found a 60 inch deck from a guy in Chillicothi,OH. I can forward the info. I would be interested in the gear box off your worn out deck. Please get back to me. Thanks
