Mower deck bx 2380 ( 2018)
whitetiger
Nov 20, 2011
3,557
1,988
Kansas City, KS
I have a loud banging under my mower deck, when mid PTO is engaged. All looks good, belts pulled etc. Any ideas?
Raise the tractor up, turn the blades by hand from below the deck. You probably have a blade contacting the lip at the bottom of the deck side sheet.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
181
186
Check and confirm the driveshaft is connected at both ends and not just the pto shaft.
A similar problem was happening on another tractor forum, and it turned out to be a broken U joint on the driveshaft.
The driveshaft was just laying on the deck and spinning when the pto was engaged.
