Moving the BX25
comfun1
b7100 with 1630c loader
Jul 28, 2015
46
Independence
I have hired a number of backhoes with operators in the past and when they are digging and wish to move them a short distance there is a technique they use. They raise the front bucket and stabilizers and use the hoe to push them forward without ever turning the seat to face forward. Do people do this on the BX25?
live_roll
M108 / BX 25 / RTV 900 / ZD331 / M7060 / B1200 Mx5100 Ford 1500
Dec 16, 2009
53
Irricana Alberta
I have done it in the past, once you become comfortable with the operating, it is a little nerve wracking initially, but it is easy to do and also if you are on soft ground it is an easier way to get yourself "unstuck". A backhoe in experienced hands can do some amazing things, I have watched some u-tube videos of people doing things with them that just make me shudder, but experience certainly helps, although with some of the stunts, common sense has to kick in sometimes I would think...
Cheers
Roger
wv bc owner
100
US
I think there is a video on YouTube of a guy loading a backhoe in a dump truck with the loader and the hoe only.
Sent from my HTC One using Tapatalk
BXinNH
Kubota BX24
Jan 31, 2015
I move my BX this way quite often when trenching. On level ground it's smooth and easy, on an incline.... not so much. You can actually practice on flat ground without digging a hole; put the loader almost on the ground, gear selector in neutral, jacks down most of the way, and then gently push or pull yourself along.
BravoXray
BX-25D, Ford 9N, Bobcat 825. Too many implements to list
Feb 6, 2014
190
Lake Winola,PA.
I put the tractor in neutral when using the backhoe so that I can move it with the hoe. I lift the loader up off of the ground, raise the stabilizers, reposition, set the stabilizers, drop the loader back down and get back to digging. I don't know if the HST could get damaged by moving with it gear, so I just leave it in neutral until I'm ready to drive it away.
Jerry
bearskinner
Sep 1, 2014
926
242
N. Idaho
Especially when digging out a large tree root ball or a large hole, You can just lift the stabilizers and push or pull the whole BX where you need it to keep digging.
