Moving materials downhill with FEL
woodsy
95 Kubota L3300DT W/FEL, 60" AgroTrend 3pt snow blower89 Arctic Cat 440 Panther
Apr 20, 2021
132
60
Maine
Just curious what to expect moving rock and gravel down a 15 deg. grade.
Will be doing some woods road work, placing a culvert in a drainage ravine
and back filling with rock and gravel.
Seems like the front end would be even heavier on a down slope than level ground
but not sure and new to FEL work so just asking.
Bmyers
May 27, 2019
3,636
4,939
Southern Illinois
Loads in your bucket will make the rear end lighter.
Some steps to help with that:
  • Use proper counter balance on the rear (example box blade, mower, etc.)
  • Keep the loader low to the ground and be prepared to push the loader to the ground if you start to loose control
  • Go slow, no need to rush, going slow gives you time to react when things start going wrong
  • If you have 4-wheel drive, use 4-wheel drive; the transmission will help keep the tractor under control
  • Take small loads until you understand how your tractor will preform and then gradually increase the load
The front end doesn't become heavier because of the slope, but your center of gravity changes because of the slope and thus effecting the balance and performance of the tractor.
Hope this helps
PS-use your safety equipment (ROPS, seatbelt), they are designed to keep you safe if the tractor goes over
Reactions: 7 users
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
124
Glendale, Rhode Island
Hello Woodsy,
I am thinking that it might be better to back down the slope! The bucket and its load would act as ballast to keep the front down. Just a thought.
Good luck with your project!
woodsy
Apr 20, 2021
132
60
Maine
Bmyers thanks for the insight and tips.
So the center of gravity is what changes in that scenario.
Knew something must be different.
And yeah backing down the slope would be an option also.
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
and stay "north/south" as opposed to "east/west" on the slope. The more you go sideways on the slope the more likely you will tend to want to roll over.
Code
l3301, fel, lp boxblade, 12" lp auger, lp bush hog, z421 zt, lawnvac leaf vac
Dec 19, 2020
146
120
Southwest Idaho
Ive moves some pretty big loads downslope and I go in reverse. Ive tipped forward a few times going down loader first never had an issue backing down. counterweight is key
woodsy
Apr 20, 2021
132
60
Maine
Have ballast in both rears so there is an extra 600 lbs back there but an added ballast box would be even better.
Went down with a 1/2 bucket (60") of rocks no problem. low range 3rd gear felt
about right. I'll have to experiment a bit.
Thanks for all the tips !
Happy to finally be able to fix that wet hole.
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Supply your own depends and you can refine your skill set cleaning some drainage ditches
torch
Jun 10, 2016
2,885
1,130
Muskoka, Ont.
According to this, back up, drive down:
SDT
Apr 15, 2018
3,693
1,417
Back down steep hills with heavy loads in bucket.
SDT
5,640
Yes back down, 4wd, low gear and the bucket down as low as it can go with out dragging
BigG
Sep 14, 2018
1,953
774
West Central,FL
1)
check out the two videos he attached to this one.
2)
