Motor stops when blades are engaged
Walker8682946
2011 Kubota GR 2120
Jul 19, 2021
Six mile, SC
2011 GR 2120. First time it stalled 10 amp fuse was blown. Replaced fuse and it worked for about an hour. Replaced PTO switch. It still stalls out after blade lever is engaged. Use jumper to by pass seat switch. Still stalls. replaced seat switch worked about 1 hour then stalled out and continúes to. When it starts to stall if you quickly put foot on brake it continues run including the mower but you can’t mow with foot on break. We are stumped including my local dealer. Help please. Thank you. Walker
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,130
127
Hardisty, Alberta
Wiring Diagram , 3 amp fuse OK?
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
If it runs with your foot on the brake the culprit may be the brake safety switch. Check it for proper operation, though it may be intermittent in which case a failure may not show by testing. You could try bypassing it to see if the problem persists or just replace it if not too expensive.
Walker8682946
2011 Kubota GR 2120
Jul 19, 2021
Six mile, SC
Finally figured it out. When engaging mower deck and it starts to stall …quickly put foot on brake pedal and it then continues to run. Replace brake switch.
BruceP
G5200H
Aug 7, 2016
847
366
Richmond, Vermont, USA
What you are describing is a WORKING brake-switch. (The brake switch is doing something when you push the pedal)
I would think the SEAT switch may be the issue.
