Modifying grapples for fine materials
Timberdoodle
LX3520, LX2980
Nov 12, 2026
9
Arizona
Late fall clean up in northern Arizona. The winter of 2023 produced over 8 feet of snow here. The pine trees responded in the spring with new needle growth and a crop of pine cones beyond imagination. The pine cones fell so thick they blanketed the ground beneath the trees to the point of making it almost impossible to walk beneath the trees without twisting an ankle. This fall the abundant needles produced from that winter began casting off and produced an exceptionally heavy needle cast. The cast off needles and cones beneath the groves of trees accumulated to depths that produced threatening fire load conditions. Following the example of California, insurance adjusters started showing up on properties here and either outright cancelling home owner’s fire insurance or stipulating demands to clean up the flammable debris and trees around homes. I’m lucky, so far, and have not been threatened with cancellations or clean up demands. However, I’ve been “eyeing” the debris accumulations since then and trying to figure out how to deal with it. On several acres it’s not feasible to hand rake this much material. I’d thought of having someone come in with a mower and mulch the acreage, but the landscape is also littered with and hiding rocks. This summer I finally decided to purchase a tractor…double duty….pine debris removal and snow removal (have a snow blower). I was skeptical at first, but the cost benefit ratio, in addition to lack of wear and tear on the body, quickly dissolved any apprehensions I had. In a matter of 2 days with a $200 pine needle rake I’ve cleaned the entire 5 acres. But, as the worm turns…I now have these huge piles of pine needles to pick up and remove. Too wet to consume by fire. By time they dry it will be fire season, not prudent to burn. Am considering another tractor implement for this. Does anyone have any experience with grapples capable of picking up large pine needle piles…or perhaps a fabricated attachment that would fit on the shanks of a grapple to enable pine needle handling? Pics? Descriptions? Thoughts?
GrumpyFarmer
5,331
Do you already have the grapple?
I am not sure there is a 100% solution… guess if already have the grapple, I might try zip tiring some snow fence to the grapple…that might help…if that doesn’t work might try cardboard(not sure how long that would last.
have you tried scooping with the bucket…you may be able to put some sides and maybe a lower piece that protrudes a bit and see if that lets you scoop more. (What’s the reason scooping no workee?)
just my couple of thoughts that I would try…I’ve not tried any of them so take with a grain of salt.
Timberdoodle
LX3520, LX2980
Nov 12, 2026
9
Arizona
No, I don't have a grapple...yet. From close up hand cleanup around the house, I do know that anything resembling a pitch fork works well Fitted expanded metal? ...I've been thinking along those lines also.
11,566
A good grapple will pick those piles of needles right up.
No need to add anything to do it.
I do it all the time.
5,782
I think the expanded steel might be a grand idea on my grapple for grass and stuff
5,782
I would think so, too. I'd also try to find a way that you can add it without being permanently attached for easy removal.
That might be the issue welding it in place along with a couple gussets would be a good idea
6,993
I agree with @North Idaho Wolfman. I use my grapple without modification to move piles of leaves and pine needles quite effectively. It won’t pick up 100% of all the leaves and needles but it picks up about 95% of the piles. With a rake on the back raking the remnants back into piles and grapple carrying the bulk of the piles off, there’s very, very little left when it’s all done.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,122
2,542
WestTn/NoMs
Well, that's good news! If I may be so bold...what grapple are you using or suggestions for considerations? TIA.
I'll second the Wolfman's recommendation. I have a LandPride SGC1060, the tines are 7 or 8 inches apart, I think. It's heavier than you need for the task and for an LX. If you find a lighter one, you could add some intermediate times.
What are you going to do with them, make bigger piles? I bet, with a little assistance, they would burn, smokey, yes.
11,566
I have a hand made grapple, I made mine quite a few years before grapples were commercially available.
This was the first version I made, the second version had more reinforcement on the top teeth.
Timberdoodle
LX3520, LX2980
Nov 12, 2026
9
Arizona
I usually use the needles to cover the trails across my property and a neighbors. Cutting firewood, I typically use my quads on those. Within weeks of use the needles are broken down into very fine matter. It saves burning and hauling them away and completely cuts the mud from those trails.
Timberdoodle
LX3520, LX2980
Nov 12, 2026
9
Arizona
Timberdoodle
LX3520, LX2980
Nov 12, 2026
9
Arizona
And what grapple are you using?????
Timberdoodle
LX3520, LX2980
Nov 12, 2026
9
Arizona
Yes, this is where I was headed when I posted the original query. I'd also considered buying another pine needle rake and modifying it so the rake times were flush to the ground and the frame upright toward the front loader quick connect, with some weld modifications. Pine needle rakes are cheap (relatively) and from past experience around the house I've always favored pitch forks to move piles of needles. Why not invert a pine needle rake??
11,566
Maybe consider these options:
