Anyone else have a problem with their mower deck that has one wheel lower than the three others and one of your leveling bolts maxed out on the high setting to be able to level the rest of the mower properly. My front right wheel is one hole different than the rest. This works when I level the deck....and when It's off the tractor (like pictured) ...all four wheels roll level. Strange. Maybe I just have a bent deck....and it was like this before I put the mulch kit on.
As far as the leveling bolts....I've thought about maybe buying a longer bolt to replace the current one....which would allow more adjustments. As of now, the only way to get perfectly level is what's shown. The Front adjustments are basically maxed out forward as well. The result is that I can't raise the front of the mower deck because the rear left adjustment is maxed....and it wouldn't be level.
The book says that my cut height # adjustment correlates to a slightly higher cut height. So a "2" on the round dial equates to a 2.25 inch cut. When I level my deck...it shows a cut height of 1.75 inch. Again, I wouldn't be able to adjust it higher because i'm maxed out on the left rear bolt.
Maybe my rear links are uneven? Going to be honest I've never tried adjusting the rear link.....I assuming the only adjustment is to keep it from going to high. Would an adjustment fix my leveling bolt issue?
