MMM Blade Sharpening
JimmyJazz
1,268
804
Pittsburgh, Pa
Hello everyone, I am about to remove my mowing deck for the first time to clean it and sharpen the blades. I am looking for suggestions on what/how to best sharpen the blades without having to remove them from the deck. I was going to use an "old school" drill powered grinding wheel. Any tips would be appreciated. Thanks !
5,658
My tool of choice is a 4" angle grinder with a cutoff wheel on it.
bbxlr8
Mar 29, 2021
432
296
Eastern PA
I remove them and actually did this yesterday on my 60" ford mmm. Not sure about the kubota's but the concept is the same. I find this allows me to get the angles & balance right.
However I must admit, I never even considered doing them while on... I learn something all the time here on OTT and will tuck this away - even just for a mid-season touch up etc.:cool:
My property is full of rocks that migrate up over time and is h#ii on my deck & blades. Also, had to break out the welder again - ugh
7,056
I’d really really recommend you remove them.
I do mine on a bench grinder.
If you don’t remove them, you have no way to know if they’re properly balanced.
If you run blades improperly balanced, you run the risk of damaging bearings in the mower’s drive. Likely a very expensive fix.
Just a suggestion.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
Just a suggestion.
Agreed.
Really, really, really recommend removing the blades from the spindles.
Easily done and allows proper sharpening by file, flap wheel, disc, etc.
