Hi again, I am continuing my search for a reasonably priced used mower deck, there is one on Leboncoin, RCK48-16B, for Kubota B1410, I have a B4200. Is tis likely to be similar enough to enable me to make it fit?
I don't know if it will be a easy match . Anytime you try to adapt something that isn't a exact fit to your tractor it's more then likely going to involve some fabrications and modifications . Saving a few $$ or so you think it will sometimes will cost you more than if you buy the proper one. Unless your good at fabrication etc: I would suggest to try and find a proper one . Good luck in which ever way you decide works best for you.
