Does anyone out there have the RCK60-24B on a B7610? I have 2 B7610s and have had the deck on both tractors. I just can't get it set so that the front of the deck will lift as high as it should in the front on either tractor.
The manual says the distance between the front stopper and the mid hanger bracket should be 3/32" and5/32".The best I can get is 1 1/4". As a result when I'm taking the machine on a half mile drive through the timber trail to mow clearings, the front gauge wheels take a beating.
If someone has the same mower/tractor combo, would you measure the clearance you have between the front stopper and the mid hanger bracket and let me know what you have?
This mower is supplied for about a dozen different tractors. I'm suspicious that it's just a compromise and the low hanging front of the deck is the best I'm going to get.
Thanks
Thanks
