Making a Howard HR12 work on a Kutoba L175
brigitte
L175, Howard HR12 tiller
Feb 15, 2014
Gans, OK
Hey all,
sorry for the newbie question :eek: but I've got an old Kutota L175 and recently was gifted an Howard HR12 rovatotor and I need to hook them up.
Any help would be greatly appreciated.
THanks.
1,006
I assume you have the three point arms on your tractor?
Back the tractor up aligned to and near the implement
On the tractor, there are two lower arms with eyes at the ends.
These eyes fit over pins on the rotavator (tiller?).
Then the upper link attaches the tractor to the top of the rotavator (center).
See this link for general instructions
http://agsafety.osu.edu/sites/drupal-agsafety.web/files/5.1%20Connecting%20Implements%20to%20the%20Tractor.pdf
And this for a video of how to do it:
http://www.youtube.com/watch?v=bSatF4QoqmI
live_roll
M108 / BX 25 / RTV 900 / ZD331 / M7060 / B1200 Mx5100 Ford 1500
Dec 16, 2009
53
Irricana Alberta
Howard Rotovators are one of the "Cadillac" tillers. Heavy, bullet-proof fine machines! Good score on getting it
Enjoy!! and have fun gardening!
Cheers
Roger
brigitte
Feb 15, 2014
Gans, OK
I managed to get the tiller attached and took it for a test run today. It seems to be only tilling about 3 inches deep. What am I doing wrong? (The ground where I tilled has never been tilled before.)
1,006
For ground that has never been tilled that seems about right.
You may have to go over it several times to get to the depth you need. Be patient and go slow. You can add weight to the tiller to try to get it to go deeper but then you start to stress the tiller and the tines.
There are adjustments on the tiller for the depth. Yours should have some runners along the sides and some method to move them up or down.
Another option would be to plow it to depth and then till that. That would assume you have a plow of some type.
2,852
Like RK said slow and easy until you get it all dug up, each pass will go a little deeper, and then just let the old gal eat, you will find stuff you didn't know was there,, First time I did my big garden I found a lot of flint chips and shards, seem the area was once covered with Indian villages high on a ridge and close to a good water source. Even found a couple unfinished projectile points, SO walk through the dirt and look close you might be surprised:D
brigitte
Feb 15, 2014
Gans, OK
Thanks so much! I really appreciate your feedback. I have a new issue now. I started a new post called "Did I fry my starter?" Do any of you live in Oklahoma? LOL
