W wjoey New member Equipment m9960 Jun 29, 2016 10 0 1 chattanooga Sep 4, 2016 #1 m So I got my 9960 Last edited: Nov 11, 2016
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,903 9,121 113 Sandpoint, ID Sep 4, 2016 #2 I would get an IR heat gun and get some real numbers, then with and check everything around it. With that info we might be able to narrow the source or cause of the high heat.
W wjoey New member Equipment m9960 Jun 29, 2016 10 0 1 chattanooga Sep 4, 2016 #3 I will do that tomorrow or Tuesday , thanks
T Tx Jim Well-known member Lifetime Member Equipment M7040 HDC & JD 4255 Apr 30, 2013 1,254 161 63 Coyote Flats,Texas Sep 5, 2016 #4 Ditto what wolfman stated. I wonder if a hyd relief valve is by-passing?
Tooljunkie Well-known member Lifetime Member Equipment L1501,home built carry all, mini plow blade. May 13, 2014 4,150 33 48 61 Lac Du Bonnet, Manitoba,Canada Sep 5, 2016 #5 Like a selector valve in wrong position, loading hydraulics.three point pulled all the way up or aux activated.
