M9540 ac
psbhouston
M 9540, ZD 331
Oct 10, 2010
15
Columbus Texas
Hopefully someone can give some advice.
I have a new compressor / system etc.
It calls for 3.7 ounces of PAG 46. When we load it into the suction side port hole - it barely takes a couple of ounces. We are turning it over and working it in. Do we need to install the compressor and then add oil?
Other compressors - we were able to load oil on the bench and then install.
Not an expert and I know just enough to be dangerous.
Any advice is appreciated.
Thanks
8,846
Yes install the A/C compressor and the drier / accumulator and split the oil between the 2.
Manually turn the compressor to work the oil through the compressor.
