I have a M9000 4x4, open station with a front end loader. It started making a growling noise. It seems to be coming from the right front. It is considerably louder with a round bale on the front. I checked all the oil levels on the front axle. Both planetarys and front axle. Front axle was just a little low. Both planetarys were full. Pulled all drain plugs and oil looks fairly clean at all 3. Removed right front planetary and inspected. It did have a small amount of metal in the oil when I drained it. All the bearings seem to be ok. I noticed that the bottom gear will move approximately ¼ inch up and down on the shaft when hub is removed. I'm not sure if that is normal. But other than that, I don't see anything wrong. Is that gear supposed to be shimmed up fairly tight or is the movement normal? I have used the search function but didn't get any help. There was one post with the same problem but nothing about what the problem was. And yes, I have checked all the wheels and wheel centers for cracks or be loose. Anything is tight and no cracks. Any help would be appreciated. Thank you in advance.
