M8580 Doesnt move in 6th gear.
rnbuck01
Tractor
May 4, 2023
South Dakota
I have a Kubota M8580 and I dont have any 6th speed at all. I was scrapeing with a box blade in 2nd or 3rd and all of a sudden it stopped moving. Now it moves but dont have the 6th gear. Any suggestions on where to start looking?
9,642
Yikes, about only one option, in the transmission!
Sounds like you've broken a gear or more.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
Yep, I agree with NIW. Does the transmission fluid have that expensive metallic look? I would stop using/driving to limit the damage.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
Possibly this will help
rnbuck01
Tractor
May 4, 2023
South Dakota
I guess I drove the tractor some more and found out that the tractor does drive in 6th gear in the opt. creep range. But has hard time moving in the L or H range. Ill have to make sure those pressures are correct like other post said.
rnbuck01
Tractor
May 4, 2023
South Dakota
I guess I checked the IC shuttle clutch operating pressure and had around that 270 psi, so Im leading towards I have a bad clutch?
