I was asked today to go and look at an M8580 4wd tractor that is used at a large chicken farm by guys that are not really tractors guys -- the 4wd does not turn on or at least they did not know how to turn on - -- I checked under neath and it appears to be turned on and off with a valve with a solenoid at each end . The wires go up under the floor of the cab. There is no switch that I can find anywhere in the cab to turn on the 4wd -- also the front axle differential lock pedal was stuck down. While under the tractor I found that the rod that engages the diff lock was under the fuel tank strap and stuck in position .
any help would be appreciated - thanks
