M7060 code 12
11,722
It appears I have found the problem...The machine is stuck in 4WD.
Is that the problem or the symptom? And who uses the word "distal"? 😂 You must be a doctor or similar.
This is an interesting thread. I don't have the fancy 4WD button on the dash in my M6060, just a mechanical up/down rod with handle to engage 4WD, which works a lot better than the lever in my MX. I have a light in the instrument panel to indicate that it's engaged, something I wish the MX had.
Al38kit
M7060
May 20, 2026
14
texas
I'm not sure what the question is...I like distal and proximal...no Doc, or similar here.
Being stuck in 4WD is the symptom of the problem...which appears to be the stuck valve...of which the cure, right now, is bigger than the problem....
I appreciate the input...and based on previous concerns regarding my ability to read, I think I'm OK there...and other basic troubleshooting, like using my Fluke...I have three of them as I seem to have too many things to fix.
11,722
No question, I just thought the word use was interesting.
I'll be following along to see how this turns out.
