M7040 rear Hydro ports
jebster
M7040
Nov 14, 2026
9
Arkansas
I have a m7040 that I’m having issues with one of the ports spitting out whatever I have hooked to it when using implements the port is new cause the old one was leaking and worn I’m guessing relief valve is messed up but unsure where to start or what to do
7,468
Spitting out the plug has nothing to do with the reliefs. Something is wrong with the new coupler.
jebster
M7040
Nov 14, 2026
9
Arkansas
Okay I have bought two new couplers and put on it and it spits them out with either one I suppose I can swap the right with the left and see if i got two bad couplers but there is something else going on I don’t think it’s the couplers I did order them off Amazon I will try and swap the right with the left but the on on the left is fairly new Amazon one as well I don’t have any issues with the one on the left
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,300
184
Coyote Flats,Texas
Welcome to this forum
If oil is leaking with male tip connected then it sounds as if inner o-ring in QD or male hyd tip is faulty.
7,468
I inylterpreted his "spitting out" description to mean the plug is coming out of the female body when under pressure. Perhaps the OP should clarify that.
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
42
32
Ozarks
jebster, a relief valve won't push a tip out of a coupler, so I'd look at the coupler/tip match first:
- Swap test: plug the same implement hose into the left port. If that tip pops out of the left one too, the problem is the male tip on the hose, not the tractor side.
- Make sure the new couplers are the same series as the tips on your implements. Ag-style tips and ISO-A tips look almost the same but don't latch the same, so the balls never fully lock and pressure pushes the tip back out. Mixing poppet and ball styles can cause trouble too.
- Get the tip all the way in until the sleeve snaps forward. If there's trapped pressure in the implement hose it may only go in partway. Engine off, work the lever back and forth to bleed it first.
- If they're breakaway-style couplers, check the mounting bracket isn't bent and the hose has some slack, or they'll release when the hose pulls, just like they're designed to.
jebster
M7040
Nov 14, 2026
9
Arkansas
Yes it is the male plug is coming out of female body under pressure when I pull lever
jebster
M7040
Nov 14, 2026
9
Arkansas
Thanks for the welcome my machine has 6000 hours and I tried to replace the inner o-rings and it didn’t fix’s my issue so I bought new ports I figured the old ones were worn from hooking up implements
7,468
The OEM couplers are made by Faster and IIRC were model CFPV. The couplers in your picture are stamped 3CFPV which is a later version that allowed connect under pressure so those look to be correct. I cant tell from the pictures if they are actual Faster couplers or a third party clone.
The Faster 3CFPV couplers are 1/2" body size ISO 7241 series A and fully compatuble with ISO 5675 male tips. The 3CFPV couplers are a sleeveless push/pull breakaway design that can be connected and disconnected with one or both sides under pressure. Are you sure you are getting the tips pushed in far enough to fully latch? Sometimes you have to push pretty hard and you have to be careful you dont pull back prematurely and unlatch them.
jebster
M7040
Nov 14, 2026
9
Arkansas
I dont know what to tell you then. Are the new couplers made by Faster or are they a clone?
I appreciate the knowledge they are clones let me do some swapping and testing and I’ll report back may be looking towards getting oem Kubota and hopefully that will be the fix thank u again for ur help and everyone’s help for that matter
BAP
Dec 31, 2012
3,216
1,324
If your old ones were leaking then they probably just needed the Orings replaced. Very common problem especially after age and use.
