M7040 hydraulic system
wingmaster
England
Hello,
There is a fill point and dipstick at the rear near the three point linkage. Is this for all hydraulics, including front end loader, and third service hydraulic on the loader, or it there a separate tank somewhere. I am assuming the oil to use is the same UDT oil ?
Thanks
JB
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,180
117
Coyote Flats,Texas
YES that dipstick at rear of tractor checks all hyd & trans oil including power steering.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
12
Northern California
Yes, Tx Jim is correct. That is your best access to the complete hydraulic system.
If you are going to change the fluid, be sure to read the manual and remove all of the drain plugs. IIRC, there are three.
altonwelch
14
Monroe, LA
In the US, my dealer says the hydraulic system should have come filled with Super UDT. And that's what I would use especially if you have the hydraulic shuttle. Not sure if you have the same fuild tradenames in the UK?
