M7040 A/C Compressor Woes
Barr Keller
M7040
Oct 6, 2023
Are there any Companies that make an Aftermarket Denso thats not pure JUNK?? Or rebuild kit? 1600$ is Painful.
jaxs
B1750HST
Jun 22, 2023
929
709
I suggest you enlist help of a real pro ac mechanic to adapt a compressor to your application. If you weld it isn't difficult to fab mounting bracket for a car compressor.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
631
599
Indiana
You likely had contamination from the previous compressor in the system. Depending on how the compressor failed, you may need to flush out the system. Also, if the system was open for a long time, the dessicant is probably no good. Water and refrigerant oil mixing can form an acid and destroy another compressor.
5,475
2,171
very likely. That or another system issue which can and often does result in compressor failure
