M6950DT Broken PTO Shaft
Salty Seminole
M6950DT
Jun 8, 2013
12
Jupiter,Florida,USA
The pto shaft that you hook implements to sheared off on my 6950. It sheared where the groove is located that the yoke pin goes into.
How hard is it to replace the shaft and can it be purchased somewhere other than Kubota ? The dealer wants over $500.00 for the pto shaft.
Tooljunkie
May 13, 2014
4,150
35
That would be like a non-wear part. So as far as a common replacement item i couldnt see it available through aftermarket dealers.
Perhaps a used one from a tractor wrecker?
There are online kubota parts dealers, maybe they will be less expensive.
Perhaps someone with a better lead will chime in. Good luck.
mrmr56
G4200, Z482, 3 G5200's
Jul 22, 2015
Waco, TX
It looks like your dealer is trying to get list price + 50%. My dealer tries to get list price + 100%. Needless to say, I order my parts from Coleman Equipment. I can't understand why greed has taken over this country so much.
Tooljunkie
May 13, 2014
4,150
35
Have seen automotive dealers adding 15-20% to retail prices, claim its to cover overhead.
Its a shame local dealers fail to attract busines with this tactic.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I don't know how new the unit is, but the PTO shaft shouldn't sheer off, the pins on PTO devices should give or the clutches should slip. Shearing the PTO is a sign something is really wrong with your PTO drive setup. Check your shear pins and make sure they are not more than Grade 2. If you have clutched implements, re-calibrate your clutch setups and make sure they are loose and not stuck together.
$500 could be cheap if you saw the bill for stripping out your PTO drive gears. Coleman's or Messick's are usually the place to get spare parts for a reasonable price.
rbargeron
Jul 6, 2015
1,185
262
western ma
Wenger's of Myerstown, PA lists one in stock for $170. (link here)
Check to see if your pto shaft is too long and pushes down on the pto when the back end of an attachment like a rotary mower raises up. The pto shaft is hardened so it won't bend much before it snaps.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,290
183
Coyote Flats,Texas
I agree to check implement pto shaft for binding. What type implement was attached to your tractor at the time of shaft breakage??
Tooljunkie
May 13, 2014
4,150
35
I believe the yoke was not locked in place and it slipped back to the end of the PTO shaft before twisting off.
If i had to guess how it broke, it would have been something along that line. Just slipping the pto shaft on and running it has crossed my mind, thinking better of it now.
rbargeron
Jul 6, 2015
1,185
262
western ma
Is it difficult to replace the shaft?
It would be good to have a look at a M6950 shop manual but from the parts list on the Kubota website it looks like a straight-forward job. Drain the oil and the gearbox unbolts. My L5450's pto has a very similar shaft/gearbox setup. There's a thread on TBN here with pictures showing my pto gearbox removed and apart. Removing the sealant took more time than anything else. Your gearbox is a bit bigger but the job should be similar. Take care, Dick B
