M6950DT. I have low pressure at injectors all of a sudden, no start and no smoke when turning over. I bypassed both fuel tanks and ran directly to lift pump, same issue. Lots of fuel under injector cover. Changed filter as well. I can hear the solenoid working as well. The stop switch is in the correct position. My next move is to pull injection pump to have it rebuild. I am not sure how to to pull the gear, any advice ?
It also looks like the collar (120) and bolts aren't there (130). Does this make any sense?
