m6040 voltage regulator
darryljr
m6040
Aug 10, 2019
Millarville
my m6040 seems to charge at low rpm but when baling at around 2000 rpm it will not charge the battery. new alternator plus a new battery all connections good. can anyone advise regulator location,
5,255
1,055
Regulator is internal to alternator.
The alternator needs to get a trigger signal to turn on. This comes via the key switch and main panel.
Check voltages at 2 pin plug at alternator according to attached procedure.
Check all fuses.
darryljr
m6040
Aug 10, 2019
Millarville
thanks dave i have a manual and have looked at that but i will try again. not sure why at high rpm it doesnt charge, i will check again and get back. it is a oem alternator so it should be okay
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,286
182
Coyote Flats,Texas
Sounds typical for worn/loose alt belt. Have you checked condition & tightness of belt lately?
