Our M6040 will, occasionally, pause after being shifted into either F or R. If you let it sit, it may then start moving after 10 or more seconds. If you take it out of gear and put it back in, it will start moving promptly. If you are impatient and open the throttle more, it will probably start moving. Once moving again, it operates properly. Dealer perplexed. Owner perplexed. No apparent reason for when it does this. Can't cause it to happen. Did it twice yesterday in 3 hours of heavy use. Has been doing this for years. No different sound in engine or otherwise when it does it. Thoughts welcome.
