m6040 parts diagram
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
Anybody got a parts diagram for the fuel system.
I am trying to identify a part on my M that I just broke while working in the woods
It is bolted to the block and connected to the fuel strainer by a small tube and has a second tube coming out of it to elsewhere in the fuel system.
Of course the tractor won't run with the tube snapped off.
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
Thanks NIW, I went there and found the fuel system diagram but the part I need is not listed although it is visible in the diagram.
It is the part with the fig# 3210XX pointing to it.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,257
161
Coyote Flats,Texas
You'll find the fuel lift pump(key 170) under the engine section under 321002(inj pump new). To chose correct part # one needs to know serial #(PIN no)
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,257
161
Coyote Flats,Texas
You're Welcome. IMHO Kubota parts surfing requires some getting acquainted with.
