Fuel was drained from separator and filters changed. I did not blow air through electric fuel pump, tractor runs 30 hours a week on a golf course. Tractor has 1700 hours and 5 year old. I am thinks it could be the suction valve in fuel supply but it does not work the same as a fuel shut off solenoid from what I can tell.Did you drain the fuel separator? Did you change the fuel filter? Do not look at it. Change it. If it has gotten water logged you will not see anything wrong. Put some diesel dryer in the fuel. I hope you did not blow through the pump itself. How many hours are on the tractor? Do you run it every day? Are you buying fuel from a busy station?
Does it run correctly after you get it running?Fuel was drained from separator and filters changed. I did not blow air through electric fuel pump, tractor runs 30 hours a week on a golf course. Tractor has 1700 hours and 5 year old. I am thinks it could be the suction valve in fuel supply but it does not work the same as a fuel shut off solenoid from what I can tell.
Jerry
Yes then problem start if it is shut off.Does it run correctly after you get it running?
