M4050 PTO Clutch Adjusment
Toyman
B7100HST, 1630, 4' Tiller, 4' Brush Hog; Mahindra 5005/Loader, Woods Cadet 84,
Apr 15, 2019
120
104
Pittsburgh
Looking to adjust the PTO clutch on an M4050. I have the Workshop manual, but it states pretty simply that if you have greater than 3/4" 'PTO clutch lever free travel' to 'Adjust by altering the length of the clutch control rod'. Has anyone completed this task? This being an older, short production model with an independent clutch (lever), there doesn't seem to be much info readily available. I pulled the cotter pin and washer from the top of the clutch control rod, but there isn't enough play at the bottom to slide it off the PTO clutch lever. It seems like either the entire clutch control rod or PTO lever needs to be removed to adjust? Thanks!
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
461
98
NZ
A photo of the linkage you are talking about would help.
Toyman
Apr 15, 2019
120
104
Pittsburgh
I'll get a pic up this evening.
9,307
You don't need or want the bottom off, just loosen the lock nut then spin the top of the shaft to adjust.
Toyman
Apr 15, 2019
120
104
Pittsburgh
As you can see below, its a 2 piece rod. I am assuming that the top (cotter pin & washer) should pull off so the shaft can thread in or out, but it didn't come off without jamming on the stud, and I didn't want to force it. Thanks!
Toyman
Apr 15, 2019
120
104
Pittsburgh
OK guys, jumped in tonite and pried the top of the clutch control rod off the PTO lever. Gave it a few turns and reinstalled. It took a good bit of leverage to remove and put a slight bend in the rod, but all in all went pretty smooth. Best part is after I fired up the tractor, pulled the clutch lever, and engaged the pto h there was no grinding.
