M4030su
KShlemon
M4030su
Feb 27, 2024
Byhalia,MS
I have a M4030su everything worked fine bucket worked , PTO worked.then I changed the hydraulic filter now nothing works, tried bleeding at pump, cracking line but nothing any help would definitely be appreciated
8,477
Try loosening the filter start it and be quick to snug the filter back up.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
666
273
Herald Calif.
I would bet the hydraulic pump lost prime. Take the suction line off the pump and pour oil into it. Most cases that'll solve the problem.
KShlemon
M4030su
Feb 27, 2024
Byhalia,MS
Thanks everybody for the tips found out I put more hydraulic fluid in than I took out , it was too full drained out until it started working, back up and running!
