M135X Hydraulic Issue
burwell
135x
May 12, 2016
Cobden Ontario
I recently purchased a M135X tractor and loader. It has 2000hrs with all new filters and oil levels are fine, but when I first start the tractor the loader won't raise for about 30 seconds when the tractor is cold. After the tractor is warm the loader will go up and down but when I have a round bale on the fork it won't raise at idle RFP I have to rev the engine to raise the loader, same with the implements when using the remotes at the back, disc won't raise at idle RPM, need to rev up the engine.
Any suggestion on what to loo for would be appreciated.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,296
183
Coyote Flats,Texas
Welcome to OTT
I'd suggest to check hyd pressure.
Tractordata shows that a Kubota loader model LA2253A in power position should Lift to full height (at 800mm): 3,477 lbs [1577 kg] & in height position Lift to full height (at 800mm): 3,135 lbs [1422 kg]
