My father purchased an LX2610 with cab last year brand new with extended warranty. Nice tractor. While visiting him in central NY a few weeks ago I noticed that one of the hood brackets that hold the hood on back by the cab had a broken weld. The tractor has 111 hours on it. I called the dealer that he purchased it from and said it should be an easy fix with a mig welder.
Two techs came out. My father left for an appointment while the techs worked on it. When my father came back to check it out and lifted the hood the weld that they did broke right off. To make matters worse the windshield was gone. My father was irate. He called the dealership and the owner was very upset as well at his techs. Apparently as they welded it the heat from the welder broke the windshield. So they said. So a small easy fix turns into a nightmare. Never say anything is easy. Hopefully this will all be covered under the extended warranty.
Just letting you all know to keep an eye on your hood brackets that attach to the frame on your LX2610.
