LX front frame attachment
test123
15
SE Wiscpnsin
I'm looking to source an off the shelft (not fabricated) front towing "eye" that I can bolt onto the existing holes of the the front frame rail of my 2020 LX2610. My application is that i want to run a logging chain / hook thru the eye so I can pull stuff (small trees, etc). I can find similiar items for BX series machines but not so much for LX. 2 questions: (1) it appears that the the front frame rail bolt pattern may be the same for LX and BX . Can anyone confirm that? (2) can anyone suggest a low cost place to find what I'm looking for. thanks,
B737
LX3310
Jun 9, 2019
2,022
2,204
I dont think the bolt pattern is the same between BX and LX. @S-G-R used these hooks from kens bolt on hooks into existing holes in the front frame rail, one on each side.
I fabbed up a D-Ring on a plate.
5,309
Inexpensive harbor freight hooks should be a direct fit (no drilling) can be mounted to the sides of your frame. I use two of them and never had an issue. I think they ran about $6/ when I got them.
Here's mine..
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Mr. "test123"
I put one in my bucket a couple weeks ago. (no reason you couldn't put it in your frame after you verify hole size)
I did the same years ago on my TG1860, which isn't technically a tractor, but my gosh that thing'll haul some stuff around ! (engine almost as large as the 'BX)
Big eyebolt
test123
15
SE Wiscpnsin
thx for all the replies--all good ideas. I probably would have gone for the harbor freight hooks... except I found this guy on ebay....
JohnstownIndustrial
(99.7% Positive feedback, 7.3K Items sold)
.... who sells this item ....
.... for $65 plus $8 delivery. he is happy to customize the dimension of the bolt holes. fabricates and ships the next day. very responsive. also sells other tractor parts and items.
MOOTS
MX6000
Jun 27, 2019
2,165
2,689
Canton, Georgia
JohnstownIndustrial
I'm confused. You said you didn't want something "fabricated" yet you are buying from an ebay seller who is doing just that.
test123
15
SE Wiscpnsin
good point. what I meant to say in my original post is that I didnt want to fabricate this item (actually- I dont have the means of fabricating). i was looking to find a product i could order online and have shipped to me quickly. Johnstown industrial is sort of a hybrid between a fab shop and a stocking seller. he makes his stock items to order and is happy to customize. maybe not for everyone but it works for me.
GrumpyFarmer
4,000
I had one of these on a previous BX. I am not sure they have something for your model or not but maybe worth a call. It was very well made(hefty)…better than the OEM on my B. I believe they are right next (or they used to be)to a kubota dealer so if you need something for a model they don’t have they can probably walk over measure/trace and help you out. They were helpful when I ordered from them in past…it’s worth a call maybe.
GrumpyFarmer
4,000
One more thought…whatever you choose, make sure you can run the loader down below grade without the cross pipe hitting your hitch…I believe that was an issue when I bought one for the BX…most places did not know, would not say or would not check…anyway maybe check that there is no inference from how far the hitch stickers out to your loader.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,359
3,165
PEI Canada
Here are mine from Kens Bolt On Hooks
