LX Cab Tractor
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
I have a 2021 lx2610su with 163 hours. It has 25x8.5 Titan Trac Loader R4tires on front and 15x19.5 Trac Loaders on rear. The tractor is perfect for what I use it for. I like the larger tires and do not need a mid pto. I would like to upgrade to a cab model lx2610 with the large tires but can not find any. Would consider moving up to a lx3310 if it has large tires. Will not use mid pto. Any help or suggestions will be greatly appreciated.
Elliott in GA
Mar 10, 2021
849
856
North Georgia
I am fairly certain the larger tires will not fit on a cab LX.
The Kubota build site should answer the question.
cthomas
LX2610 HSDC
Jan 1, 2017
849
563
La Farge Wi
I do not know if Kubota offers it now, I do know in 2020 they didn't. And yes I suspect the larger tires would interfere with the mower deck, but, Kubota also said my 2 inch spacers will not work with the 60 inch deck and it works fine. You might have find a large dealership that will order the tractor and the larger tires and then swap them. Or you have to buy both and then resell the small tires. Also the cab with larger tires is going to have a higher center of gravity.
NorthwoodsLife
Oct 15, 2021
1,411
1,472
Wisconsin
I have a LX2610 Cab model and I do love it. I can't see why you couldn't install large tires on one since you don't use or want to use the mid PTO. I don't think the fender clearance is any different on the standard cab LX and the SU. I think that it's just mid PTO issues if you want a mower deck... but I could be wrong.
Personally, I'd buy a new LX2610 with cab, and have the dealer swap the tires out to the one's you currently have. They could or Should give you a discount because they'll have 4 brand new wheels and tires.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,594
3,994
PEI Canada
I have the larger tires on my 2021 LX3310 cab. Tell your dealer to order
(2) ABR 8646 25x8.50x15 R14 SR
(2) ABR 8645 15-19.50 R14 SR
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
Thanks
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
Personally, I'd buy a new LX2610 with cab, and have the dealer swap the tires out to the one's you currently have. They could or Should give you a discoaunt because they'll have 4 brand new wheels and tires.
Thanks
Thanks
cthomas
LX2610 HSDC
Jan 1, 2017
849
563
La Farge Wi
I agree with the R14 tire suggestion as they are so much better than just R4 tires.
S-G-R
Jun 17, 2020
1,594
3,994
PEI Canada
Dave has the larger R4's on his cab 2610
PaulL
2,691
1,683
NZ
Buy the LX cab model with normal wheels/tires. Swap the wheels between old and new. If it doesn't work, put them back. Sell your non-cab LX with either the standard wheels (if yours fit the cab model), or the large wheels (if they won't go on the cab model).
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
DennyC
2021Kubota lx2610su
Jun 21, 2023
19
Georgia
Thanks. I was thinking about doing that if Ican not find a cab model with larger tires.
